how to tell shifters are updated
Posted by steve in wi on March 25, 2011 at 17:47:36 from (69.171.163.90):
I just picked up my second 706 and the both shift the same.they don't seem to shift bad at all,but how would i tell if the shifters had been updated,is the mechanism's the same or it all under the cover.I never been up close to see what the difference on the 56 series vs the 06.I what to do what i can now since i have both tractors in the shop or maintinence.How good is the 282 diesel on fuel just rebuild the motor so very curious.Just getting the sleeves out.Thanks steve
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
