Re: '51 Farmall H Sheet Metal?
Posted by sflem849 on March 25, 2011 at 17:57:21 from (69.197.84.192):
In Reply to: '51 Farmall H Sheet Metal? posted by Bill From Virginia on March 25, 2011 at 17:08:20:
OEM Tractor Parts. He might as well buy another tractor if that has good ones! Their prices are getting nuts.
Are you sure you can't fix the metal that is there? You can even patch up metal that is missing. You would generally be better off to take it to a body man to see if he can repair it.
