Re: Water in 140 gas tank
Posted by bobs old iron on March 25, 2011 at 23:22:55 from (75.171.156.235):
In Reply to: Water in 140 gas tank posted by seeya_later_gator on March 25, 2011 at 18:20:53:
your 8-n cap is under the hood, like my TO-20, never gets h2o in it. my 230 cap is exposed to weather, if it get to cold, condensation builds inside. also every time you open cap in moist climates, guess what, unless you are getting fuel from a station that don't sell fast enough to keep from h20 build-up.
