Re: Famall H Lift all
Posted by Joe Dowling on March 26, 2011 at 03:31:35 from (184.61.117.132):
In Reply to: Famall H Lift all posted by 660 guy on March 25, 2011 at 13:28:12:
I've had problems with my '52 H lift all twice. Once the lever return spring broke and jamed the gears, twisted off input shaft. New gears fixed that. Another time I had a needle bearing go bad and chew up the pump housing. I had a machinist friend repair the housing as it is not available. My bet is your pressure relief spring is too weak. I shimmed mine to up the pressure so I could lift a small building with the loader to put it on a trailer. Pressure guage is the way to tell. Good Luck.
