Posted by K-Mo on March 26, 2011 at 05:29:53 from (67.55.164.37):
In Reply to: Cub Ring gear posted by BEL@IN on March 26, 2011 at 05:04:15:
Which "ring gear"? If you mean the differential ring gear, then yes that requires complete disassembly of the transaxle assembly. After ring gear replacement, the mesh and backlash need to be adjusted by adding and removing shims on the differential bearing carriers and the lower transmission pinion shaft. It would be best to replace a matched set ring gear and pinion from the same tractor. Mixing used gear and pinions from two different tractors could have different wear patterns. K-Mo
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
