Re: Famall H Lift all
Posted by riverbend on March 26, 2011 at 05:44:17 from (74.37.50.81):
In Reply to: Famall H Lift all posted by 660 guy on March 25, 2011 at 13:28:12:
I had the pump apart on my '40 H recently. It is easy to work on and when something is wrong, it is pretty obvious. I'm sure it is several pages back, but I had posted the free length of the new springs.
The only trick is to jam the pump gears with a length of strap iron to remove the drive coupler. Clean the outside before you open the reservoir and keep the inside spotlessly clean.
When mine wouldn't lift the cap had come off the pressure relief valve and several of the springs were bad.
Greg
