Re: What do you think of a 460 farmall?
Posted by sflem849 on March 26, 2011 at 06:07:55 from (69.197.84.192):
In Reply to: What do you think of a 460 farmall? posted by Zachary Hoyt on March 26, 2011 at 05:43:43:
Zachary Hoyt said: (quoted from post at 05:43:43 03/26/11) As I understand it the 460 is a continuation of the H/SH/300/350 line and the 400/450 were succeeded by the 560. The number jump is confusing, but I guess there are only so many numbers available to use to name tractors, so what could they do?
Zach
I should have stated that better when I gave letter/number examples. I would guess (I will probably go do research) that a 460 diesel had just as much motor as an M plus a little weight.
Max Hp is 46 and at rated speed it was 44.40. That would put it at more than an M (unless it had some mods). They ran it at 9139 lbs!!! Bare it was 6055 so it is only a hair bigger than an M.
They say the M is 36.07 at rated speed and 36.66 hp max tested. They don't give a weight, but they say they added 750 lbs of cast weight. That would put it at around 6500, probably less.
This post was edited by sflem849 at 06:58:21 03/26/11 2 times.
