Re: Replace alternator belt on 300
Posted by old on March 26, 2011 at 14:19:07 from (4.245.12.181):
In Reply to: Re: Replace alternator belt on 300 posted by zlarryd on March 26, 2011 at 13:58:19:
The way the fan pulley works is there are 1 or 2 lock type bolts/screws that hold the slip part tight. When you need to tighten the belt you close up the pulley which pushes the belt out more and tightens it up. So you loosen up the lock screw/bolt and turn the outer part of the pulley to loosen up the belt. Warned they can be a bear to get to turn and may take some TLC and a choice word or 2
