Re: H firing problem
Posted by Janicholson on March 26, 2011 at 17:00:10 from (67.72.98.45):
In Reply to: Re: H firing problem posted by Bob on March 26, 2011 at 15:33:25:
Bob is very correct. A piece of tag board with a hole in it for the rotor shaft and marks for the clip locations for the cap, can help locate the position of the rotor. Put the rotor on over the paper, put a plug in the coil wire, and ground it. Then turn the engine slowly and watch where the rotor points at a spark. then compare it to the cap ! Jim
