Re: H firing problem
Posted by Janicholson on March 26, 2011 at 17:24:25 from (67.72.98.45):
In Reply to: Re: H firing problem posted by pintobill on March 26, 2011 at 17:17:28:
Broken rotor drive tab inside
Wrong rotor
Wrong cap
Wrong set of points (very possible if they are not the stock type as the rubbing block might be in the wrong place. Jim
