as an educated guess it sounds as if the starter drive is not engaging with the ring gear, causing that grinding noise. can you pull the starter off and have a look at the drive and see how the teeth look on it and check ring gear also.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
