Re: H firing problem
Posted by bc on March 26, 2011 at 22:33:09 from (69.151.186.17):
In Reply to: Re: H firing problem posted by pintobill on March 26, 2011 at 17:17:28:
I wonder if you have a problem with the distributor shaft or bearings allowing it too wobble a little. Check it for side to side play.
