Re: Loud Grating/Grind Noise Not Starting-1972 IH 454 Diese
Posted by 495man on March 27, 2011 at 03:46:56 from (69.60.67.215):
In Reply to: Loud Grating/Grind Noise Not Starting-1972 IH 454 Diesel posted by Wayne L. Rickert Jr on March 26, 2011 at 17:37:09:
I agree wit rustred. My guess is starter not engaging ring gear, worse case is teeth stripped off ring gear right where the start is at now.
Any way you can coast/pull start it, or at least pull it a few feet to advance the ring gear, perhaps the start will grab then? That will prove if it's the ring gear or starter.
