First I'd start with a checking if this "H" is original. All "H" models came 6 volt and positive ground. What do you have can be anything else.
Why anyone wants to or has to make these tractors 12 volt is beyond me. They are puurrrrrfect with 6 volt systems and the proper 2 ga. cables. I don't know if your "H" is a 6 or 12 volt as you have left out sooooooo much important info as to making any guess to why your tractor is not charging. In your system you have many parts....but in a quick fix on a tractor you have NO knowlege of it's past or present state I'd do this first. If your tractor has been stored without a battery for a while, or generally has charging problems, you may need to repolarize your generator. You need to do this anytime the generator or regulator has been removed or the leads disconnected. This is a really easy procedure, and requires only a short piece of wire. First, make sure that the positive terminal of the battery is grounded. Then, momentarily connect a jumper between the "BAT" terminal of the regulator and the "A" terminal of the generator. Hold the wire on one end and just brush it across the other - you should see a spark. If you do see a spark, you're done. It is that easy. Remember, don't connect the wire, just momentarily touch it. And make sure you have the right terminals at both ends (they should be labeled). If you do the wrong ones you're likely to fry your regulator.
...........buyer beware, Good luck
This post was edited by 1950whiteC at 12:20:32 03/27/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
