Re: my first tractor :)
Posted by tractorsam on March 27, 2011 at 14:40:32 from (71.7.207.34):
In Reply to: Re: my first tractor :) posted by caspermj on March 27, 2011 at 06:36:50:
Anything from a Super A through a 140 should fit with the exception of the one point hitch stuff unless you're lucky enough to have one and stuff from an A can sometimes be adapted to work. There's not a lot of it floating around so if you see something go for it. You might find you have to buy a tractor to get the implements some times. That said with a little ingenuity there is a lot of stuff that a fellow can make himself. Sam
