Re: Carburator
Posted by Farmall Bob on March 27, 2011 at 15:56:36 from (76.179.113.97):
In Reply to: Carburator posted by oldiron29 on March 27, 2011 at 14:56:30:
I like the Zenith better, but I have taken the Carters apart to cleaned, adjusted and used a new rebuilding kit with satisfaction. Sounds like the float needs adjusting on your Carter? It may be sticking or hitting to one side, it needs to work freely. Also it may be the float is too high allowing to much gas into the bowl? Do you have a manual?
Bob
