nope aint no need to take the top off theres enough room to wiggle the drive shaft back on there. you could remove the belt pulley if you like its straight under thebelt pulley. A little trick ive found theres a "openface " bearing that the drive shaft slips up on take a small rubber band and wrap around that bearing to "pull the needles together" where the driveshaft will slip over the needles. you can run the tractor with out the belly pump also
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
