If the ring gear is bad, that requires that the tractor be split in half to access the flywheel at the rear of the engine.
The clutch and pressure plate needs to be removed, then the flywheel.
The ring gear wraps around the flywheel, and is a shrink fit. The old gear needs to be cut off with an acetylene torch. The new gear is heated and dropped on to the flywheel.
While you're in there, you may need to have the flywheel resurfaced. You may need to replace the clutch and pressure plate. You may need to replace the IPTO drive gear. You may need to replace some seals.
It sounds like you may want to have this service performed by a mechanic. Splitting a tractor is a pretty advanced task.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
