Re: Installing a starter on a non starter Farmall A
Posted by gene bender on March 28, 2011 at 08:41:18 from (67.55.227.7):
In Reply to: Installing a starter on a non starter Farmall A posted by PoppinJohn720 on March 28, 2011 at 07:56:02:
Yes the bell housing and flywheel will need to be changed. Yours mite have the flywheel grouve to accept the ring gear hard to say as later in prodiction they did leave the factory with flywheel grouved for the ring gear.
