Re: Installing a starter on a non starter Farmall A
Posted by sflem849 on March 28, 2011 at 08:44:21 from (69.197.84.78):
In Reply to: Installing a starter on a non starter Farmall A posted by Enar on March 28, 2011 at 08:02:39:
Your tiny little motor really won't make any power when you time it like that.
OP - You are JD man. Just use the belt pulley like any good JD guy. :lol:
