Re: Installing a starter on a non starter Farmall A
Posted by rustred on March 28, 2011 at 09:14:50 from (209.115.232.65):
In Reply to: Installing a starter on a non starter Farmall A posted by PoppinJohn720 on March 28, 2011 at 07:56:02:
why not just set it at factory spec.s, which i believe is TDC and will have no problems. its when people have the timing advanced more than called for, when the surprises start happening, like the kick backs. not worried about hand cranking any of mine, including the wd9, as the little A is not even classed as exersize.
