Re: Cub 6 Volt Battery Discharging Getting Hot
Posted by RTR on March 28, 2011 at 10:53:14 from (216.226.179.180):
In Reply to: Cub 6 Volt Battery Discharging Getting Hot posted by Andrew Z on March 28, 2011 at 08:47:28:
What does it mean I need to do if the cut-out is stuck? Do I need to purchase a new regulator, or is it an easy fix?
The starter motor isn't stuck because the tractor was running when it was unloaded off the trailer. The guy had to crank on the starter for about 20-30 seconds before the engine even fired. Therefore I know the starter works well.
