Re: Antique tractor estimated value
Posted by CenTex Farmall on March 28, 2011 at 11:05:17 from (166.128.160.250):
In Reply to: Antique tractor estimated value posted by Susie Grosvenor on March 28, 2011 at 10:41:13:
If you have a photo you could post that would be most helpful. So much depends on Engine and internal conditions and the condition of the tires.
Tires alone can swing the value of an antique tractor by $1000 dollars one way or the other.
Unfortunately the basic value is based on what it weighs at a scrap yard and goes up from there. If there is other equipment that goes with it or is mounted on the tractor that creates more value. Or if a machine has certain optional equipment.
Post a photo if you can.
