Re: 656 tappet cover
Posted by pete 23 on March 28, 2011 at 16:31:14 from (173.87.15.2):
In Reply to: 656 tappet cover posted by Vapet on March 28, 2011 at 11:38:39:
IH gaskets set still come with the neoprene gasket and they must be free of oil to seal properly. I put them on dry. Don't over tighten. Of course , like others have said , cover must be straight. You could of course use silicone but it will require letting it partially cure before you tighten it down or zip, out it will go. I'm talking gasoline engine here. Diesel uses a composite gasket and I glue it to cover. That cover is harder to get straight so silicone will make up for some imperfections.
