806s could have 1 of two pumps. the early ones, at least partway into "65, originally came with the IH made model RD pump. The later ones used the Roosamaster model DB. many early tractors were changed over to the roosamaster.
the RD pump has a valve on the underside of the fuel supply pump (back end of injection pump) that has to be opened while bleeding the filters, then closed to run. the roosamaster has both fuel filters before the supply pump, which then feeds directly to the IP. so just crack the two vent screws, close when the bubbles stop, and start "er up.
if you had water go through the IP, that is a bad thing. others can address that.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
