Re: 806 D ran rough, died, won't restart
Posted by Bill Lisbon on March 28, 2011 at 17:02:14 from (69.89.163.245):
In Reply to: 806 D ran rough, died, won't restart posted by dmiller on March 28, 2011 at 16:49:41:
Sounds like you have dirty fuel filters. When did you change them last? I would change filters. Make sure you have at least half a tank of fuel, open bleeder on first filter till fuel comes out without air bubbles, then do the same to the second filter, then open the fuel line going into the injection pump, make sure fuel comes this far, close line. Try to start tractor, if it does not start, open the lines going to the injectors. Then chank engine until fuel comes out of the lines, tighten all the fuel lines, tractor should start.
