Re: Cub 6 Volt Battery Discharging Getting Hot
Posted by Brownie 450 on March 28, 2011 at 17:36:03 from (66.43.241.198):
In Reply to: Cub 6 Volt Battery Discharging Getting Hot posted by RTR on March 28, 2011 at 08:47:28:
I'm thinking you have a pull-type "mechanical" starter switch on the starter. Are the triangular shaped insulators on each side in good shape? If you tightened the cable on this switch, & didn't hold the stud from turning, the stationary contact could be grounding out on the switch sides.
If you have a solenoid / key switch, this won't apply.
