Re: Which hydraulic oil to use ???
Posted by Tom Fleming on March 28, 2011 at 18:40:32 from (67.20.243.240):
In Reply to: Which hydraulic oil to use ??? posted by Sam F. on March 28, 2011 at 18:33:11:
Standard hydraulic oil will work just fine. They originally used SAE 20, non-detergent oil. CIH sells Hytran, which will work just fine.
Clean and no moisture is the most important. do NOT use detergent oil.
