Posted by oldtanker on March 29, 2011 at 06:57:25 from (66.228.255.223):
In Reply to: 706 Smoking Bad posted by JDE on March 29, 2011 at 05:48:07:
1st, color of the smoke? White=unburned fuel, blue/grey=oil, black=too much fuel.
If white or black....
Did you check the compression? A lot of times a rebuilt pump and injectors will put the correct amount of fuel in the engine that because of valve of ring condition it's no longer able to get a good burn or just the injector pump was rebuilt but the injectors themselves need redone. (white smoke). Other thought would be that the pump is turned up to high (black smoke).
If it's blue/grey then you have an oil problem. Could be stuck or worn oil control rings or valve seals.
Rick
This post was edited by oldtanker at 06:59:10 03/29/11.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
