Re: Re: Touch Control Overloading
Posted by big fred on July 23, 2000 at 15:09:54 from (208.51.245.66):
In Reply to: Re: Touch Control Overloading posted by Les Repair on July 23, 2000 at 11:46:10:
ALso, if you take that valve block off the tractor and disassemble it, (I wouldn't try this unless it was disassembled) you may find that even though that screen is clean, you may have a bunch of trash in the hole the screen sits in. On my 300U I found what I call a "hairball" about 1/4 inch diameter and about 3/8 inch long sitting in there packed around the screen. Tweezers and compressed air cleaned it out. DOn't know if that would cause the obstruction you are seeing though.
Post A Followup
: Re: Re: Re: Touch Control Overloading
