Re: Did MDs have an ignition switch?
Posted by Bob M on March 29, 2011 at 14:55:05 from (67.240.171.41):
In Reply to: Did MDs have an ignition switch? posted by sflem849 on March 29, 2011 at 13:34:31:
The only MD I ever fooled with did not have an ignition switch at the operator's station. It did however have a switch on the intake manifold to ground the mag when the starting lever was in the run (diesel mode) position.
On this one you could shut the engine down quickly when it was running in gas mode by simply throwing the starting lever to "run" and leaving the diesel throttle handle in the "no fuel" position.
