I don't know too much about 230s, but your problem could be a bad condensor. It normally isn't too hard to replace. Your problem may also be bad fuel flow. Take the fuel line off the carburetor and turn the gas on at the sediment bowl. If you get a full stream coming out of the line, your problem isn't above the carburetor. If, however, a weak stream appears, take the line off and blow it out. If that doesn't work, take the sediment bowl off and check the screen. Also run a wire into the gas tank to loosen any trash that may be plugging the hole. If nothing so far has worked, proceed with the plug wires (don't forget to number them - I know from experience!) before entering your carburetor and checking it out. Maybe someone who has worked on 230s chime in and help you out. Good luck, SF
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
