Re: 230 Farmall starts then dies
Posted by MK in Ontario on March 29, 2011 at 17:01:14 from (70.54.105.86):
In Reply to: 230 Farmall starts then dies posted by MarkinMo1 on March 29, 2011 at 16:51:45:
Have you checked fuel flow to the carb. That is the next thing you should do. Odds are great that is your problem. Check that it flows out of the tank at the fuel bowl first, then if good there, take off line at carb and check there, and if good there I'd take the plug out of the carb and see if it runs good there. We just had a freshly rebuilt carb do that to us. Turns out the float was bottoming out on the casting and not letting the needle drop far enough to flow properly. That won't be your problem, but you could have crud in the system. Check the inlet screen in the elbow to the carb is clean, if there is one. Markus
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
