Re: Did MDs have an ignition switch?
Posted by Bob M on March 29, 2011 at 17:19:53 from (67.240.171.41):
In Reply to: Did MDs have an ignition switch? posted by sflem849 on March 29, 2011 at 13:34:31:
Good practice! If the engine's gonna sit more than a few days the gas left in the carb begins to go stale as the lighter fractions evaporate. This can make starting more difficult. Running the carb out on shutdown insures there will be fresh gas in the carb the next time you go to start. (Note this applies to gas engines as well!)
Adding a kill switch is not a bad idea. Be sure to keep the kill switch closed (mag grounded) when running in diesel mode. Doing so will extended the life of the breaker points inside the magneto.
