Re: super C
Posted by karl f on March 30, 2011 at 07:35:49 from (209.188.106.159):
In Reply to: super C posted by stan bainter on March 30, 2011 at 05:42:44:
You can convert the compression ratio specification (usually found in your I&T manual) into psi close enough for diagnostics. The atmosphere is about 15 psi. Say your engine is spec'd at 6 to 1 compression ratio. 6 x 15 = 90.
your engine is obviously in the 10 to 1 area.
karl f
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
