Re: 230 Farmall starts then dies
Posted by El Toro on March 30, 2011 at 07:48:59 from (108.3.156.106):
In Reply to: 230 Farmall starts then dies posted by MarkinMo1 on March 29, 2011 at 16:51:45:
You need to make sure you have battery voltage to your coil when it quits. With the points open you should have battery voltage on both small terminals on the coil. You need the ignition switch in the on "position". You may want to remove the screen behind the fitting where your gas line connects if you're getting good flow from the tank. The screen could be blocking the flow to your carb from rust and dirt. Are you using a ballast resistor? It could cause that if you have one. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
