Re: H water pump thrust washer
Posted by pete 23 on March 30, 2011 at 10:13:42 from (74.44.100.190):
In Reply to: H water pump thrust washer posted by jb-h on March 30, 2011 at 08:12:11:
There is no seperate thrush washer on the H water pump impeller. It is machined surface on the impeller and shaft and it rides against the shoulder of the bushing. The impeller blades run close but I don't have a particular distance in my head here. Maybe 1/16th inch or so. Also, the bushings were not a replaceable item through IH all the years I repaired those pumps. You pressed out the whole center section. On an M we replaced bushings seperately.
