Posted by LaBoyteaux on March 30, 2011 at 13:27:20 from (76.14.94.14):
In Reply to: Hauling M tractor posted by jerry hakenwerth on March 30, 2011 at 13:00:52:
I agree with the other advice you have been given. I would add that you should drain the tires by rotating the valve stem to the bottom and removing the valve core. Refill with air only. This will reduce the weight. I would not attempt reversing the wheels (dish in) until you get home unless you have a small crane on your rig. Water filled tires usually have a two piece valve stem. The rust makes me thing their may be salt water in the tires too. A repaird is not too difficult once you have the tire off the rim but a new or used rim may be easier.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
