Re: 130 loose steering
Posted by tractorsam on March 30, 2011 at 13:30:16 from (71.7.207.34):
In Reply to: 130 loose steering posted by caspermj on March 30, 2011 at 06:03:44:
Keep us posted on what you find. If you need parts give me a buzz I know where I can probably scare up some parts for you locally. You are also lucky to have a CaseIH dealer who is very good with the older equipment. Sam
