Posted by old on March 30, 2011 at 17:02:39 from (4.245.15.17):
In Reply to: Farmall Cub won't start posted by SouthernFarmall on March 30, 2011 at 16:47:15:
You should have a drain plug in the bottom of the carb. Turn your gas off, pull that drain plug then catch the gas with a coffee can etc. You should get a good steady flow of gas there. If you do not then you have a sticking float and you might be able to free it up by tapping on the side of the carb with a screw driver handle etc. . If you have a good flow there but no start try holding your hand over the air intake area of the carb and hit the starter button and see if it starts. BE 100% sure it is out of gear and check that 3 time. You should feel a good suction there when you do that. If you don't then sounds like the shop did some thing wrong
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
