Re: H Carb, RustyFarmall
Posted by rustyfarmall on March 31, 2011 at 08:07:30 from (209.152.78.140):
In Reply to: H Carb, RustyFarmall posted by GordoSD on March 31, 2011 at 08:00:02:
The main metering stem is removed with a deep well socket. It has no tabs. If you are referring to the idle metering jet, the only way is to drill and re-tap the threads.
My email is open if you use the "modern" version.
