Actually Ford used that same axle(may have been slight variations as the years passed) all the way up into the 40's.
It's a very well-done swap though! I have an F-12 with what's apparantly an old Buick axle wide front conversion(one of the "Buick" hubcaps is still on it). It wasn't nearly as well done as this one- the axle had been cut apart and narrowed in the center, and instead of lug bolts, the wheels are just welded directly to the hubs, probably made tire changes a booger! One of these days I'll get pictures.
I find stuff like this just as interesting or even more so to look at than just another run of the mill restoration..
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
