Re: 3 pt hitchs
Posted by old on March 31, 2011 at 15:05:12 from (4.245.2.245):
In Reply to: 3 pt hitchs posted by Robin Hood on March 31, 2011 at 14:49:13:
Well if your any good doing metal fab work it can be done for $200 of so if you have the steel on hand and buy a cylinder and a pair of 3 point arms. I have built a couple from the ground up over the years but I had the 3 point arms from dead tractor and have hyd cylinders laying around. First one I ever did was on an Oliver 77 looks bad but work good but I did that 15 plus years ago
