Posted by CNKS on March 31, 2011 at 18:53:28 from (216.144.104.128):
In Reply to: 3 pt hitchs posted by sflem849 on March 31, 2011 at 14:58:04:
Yes, the factory 3 points are better. The tel-a-depth on my 460 makes the fast hitch much easier to use compared to the Saginaw. But, without one all you can do with a letter series tractor is pull implements. I have two Saginaw 3 points, will eventually have two more. A 3 point allows me to use a bushhog, sprayer, blade, 3 point disk, and drill, used a mounted chisel once. The only thing you need draft control for is plowing. I haven't plowed in several decades. Didn't have draft control then either. In other words it makes a letter series useful.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
