Re: A exhaust manifold outlet threads stripped
Posted by bermuda ken on March 31, 2011 at 20:46:53 from (71.82.164.143):
In Reply to: A exhaust manifold outlet threads stripped posted by Sam F. on March 31, 2011 at 20:03:26:
Once you get the threads fixed....add some oil to the threads on the pipe before you tighten it. Get it VERY tight(use a "cheater" bar).
You do not want the pipe to vibrate loose and cause the same problem you have now.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
