I had the manifold retapped by a plumber as mentioned below, but the threads still were not very good as the old pipe had pretty much worn them away. I had a "fresh pipe" cut and new threads cut on it then turned the pipe in with steel wool wrapped around the pipe to make it even tighter. It held for about 5 years then I finally had to spring for new manifold - they aren't that expensive.
The pipes I've seen welded in don't last long especially if the tractor is seeing lots of field work.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
