Re: Farmall 450 Ball bearing found while draining
Posted by Theman on April 01, 2011 at 10:11:47 from (65.198.133.254):
In Reply to: Farmall 450 Ball bearing found while draining posted by Tony_Idaho on April 01, 2011 at 08:40:01:
Tony, If all - that's ALL - bearing cages are intact, I would agree with your assessment. I am unsure if there is enough room (at least 5/8") between the bull pinion shaft and the cast iron bull pinion cage on the 450 to let a ball fall out if a bearing failed. For me, a ball bearing floating around in the rear end would be reason enough to pull the cover and go exploring.
