Re: A exhaust manifold outlet threads stripped
Posted by Brian Dan on April 01, 2011 at 12:02:50 from (24.179.177.168):
In Reply to: A exhaust manifold outlet threads stripped posted by Sam F. on March 31, 2011 at 20:03:26:
IH service departments used to have a tap for repairing exhaust manifolds. Did you check with you local Case IH Dealer service department?
