Re: A exhaust manifold outlet threads stripped
Posted by sflem849 on April 01, 2011 at 13:17:06 from (69.197.84.78):
In Reply to: A exhaust manifold outlet threads stripped posted by Sam F. on March 31, 2011 at 20:03:26:
I had mine welded on my SMTA. Take it to a (good) shop and you are good to go. You can't weld it as home as good as they can do it. A tap was never going to make mine work again.
