Re: digital tach again
Posted by Janicholson on April 01, 2011 at 14:05:38 from (199.17.6.26):
In Reply to: digital tach again posted by timis on March 31, 2011 at 21:39:54:
Even with a regulator, the tach is likely to have issues with a very noisy (electrical EMI) tractor. Some will work, others will just show the bizarre spiking in the electrical system. A 300MFD capacitor on the power lead to ground might work. Put a 100 ohm resistor across it to discharge it when stopped. Jim
